dajohnson53
- Apr 28, 2004
- 1,627
Hi: I've been working on an overheat problem:
http://forums.iboats.com/showthread.php?t=220135
Removed exhaust and water jacket covers, cleaned them up as best I could, replaced with new gaskets, and torqued to spec and tightening sequence in OEM shop manual. I tightened in 4 stages.
Shop manual does not call for any sealer or adhesive for these gaskets.
Ran it in a barrel for about 45 minutes. The good news is that the engine seems to be circulating water perfectly, and the tell tale and heads were luke warm. Water jacket cover seems perfect.
Exhaust cover has tiny water leak(s) which produce a drop every 5 minutes or so. This isn't a lot of water, but it's there. I looked and it seems to be weeping out of more than one different places.
I do not know if I can possibly clean the surfaces any more. They are not pristine, this engine is 30+ years old and there is some "irregularities" in the mating surfaces. On the other hand, before I got into this, there was no water leaks, so I don't know if that's an issue.
What should be my next steps? Even though the manual doesn't call for sealer or such, should I use it, and if so, what type?
Should I just evenly add a couple more inch-lbs to each bolt?
Can I take it all apart again and try to clean it up better or add sealer - in other words, re-install the same gaskets?
I have never done gasket work before, so I was just following procedure in the book and what I read on these forums. I'm pretty clueless when it comes to troubleshooting this.
Thanks in advance.
Thanks in advance.
