Re: maycraft 18- how to aviod the rot
iwhitevt, I think you have made a good choice in going with the Maycraft. It seems as though the general consensus is that wood in boats now a days is bad. That's entirely not true. Poorly constructed boats are bad. While I don't have any direct experience with their boats, I am always hearing great things. If you can see into the bilge, check for any signs of exposed wood. If you see it have it addressed/sealed by the dealer or builder before you accept delivery. If you mount anything on the boat, especially on the transom, don't skimp on the sealer. I like to use 5200 from 3M for those things you won't have to remove, 4200 for the things you do.<br /><br />Jack has it right, check all compartments in the hull that you have access to for drainage. If the gas tank is under the floor make sure there is a plug to drain that compartment. The last thing you need is rotten wood and a leaky fuel tank. I always pull every plug when my boat is high and dry. Other than those things, there's really not much you can do to prevent rot. If the boat was built right, it won't rot. Good luck and have fun with your new toy!!
