Hello,<br />I have been to some max RPM tuning recently (motor tuning, motor transom height, new prop) and generally Im OK with the results. To start with, I was getting 4600rpm with 21 pitch aluminum prop (25 panga style boat, 140 HP). After adjusting the WOT (was not getting a 100% aperture), fixing some minor flows, raising the motor a notch on the transom and putting 19 SS she makes some 5300rpm at WOT and almost 34mph with medium load (4 persons, regular fishing equipment). Im glad with the acceleration and planning, so assuming the motor is in proper position on the transom (several opinions agree here), my questions are:<br /><br />1. Is it worth putting 17 prop to meet the 5500rpm? From the engine degradation point off view. Id gladly stick to 19, Im more interested in speed@rpm than in the hole shot, Im also getting the 19 SS for a nice price
How about the over revving risk?<br />2. I am considering dropping the hydrofoil to limit the drag, as my experienced friends and I see no big improvement in planning performance (long boat, no deep V, usually running fast). How much rpm change (if any) could I expect in the planning range without the stingray?<br />3. In your particular cases, how much rpm/speed difference have you obtained raising the motor on the transom, by say ½ or 1?<br /><br />Any opinion will be appreciated!
