Mariner 5 hp dies under load and fouls plugs
GKLAUS
I have an older 5 hp sailboat kicker. It was completely rebuilt last year. It runs great out if the water but as soon as I put under load in the water it dies. I have tried adjusting the throttle and the fuel mixture a least 20 times and it will run fine for a while but as soon as I attempt to put in gear (at a lower idle) it dies. If I get it to to run it never runs at full throttle and seems to want to die, or does die, as soon as I slow the throttle down. We got it to run yesterday, went for a sail and after about one hour of sailing attempted to start it up , it ran for about 3-4 minutes and then died again. It would not start again untill I changed the spark plug for a fresh one. I have tried this a few times and a fresh plug works for a while then the whole process starts over again. Any ideas? Would a higher octane gas mix have any effect?
Re: Mariner 5 hp dies under load and fouls plugs
Ayuh,.... Welcome Aboard,... Sounds like the carb needs Rebuildin', insteada just adjustin',...
Bosunsmate
check the fuel float floats properly.
try squeezing the fuel primer bulb with engine off to check it stays firm
