finished work and got the chance to leak test my brazing job. solid as a rock and not going anywhere. It will still get a few layers of coat-it epoxy on each side just for good luck. so... the brazing worked but i think it would work a little better if I could have gotten the area hotter faster and kept the torch moving more. all in all I am pleased with the results. I wouldn't do this on thinner aluminum though.
Got a long list pf things left to do.
1. prop up the console above the stringers- leaving it attached to everything cause I can work around it and I don't want to reconnect everything
2. clear all the old stringer and floor rivets
3. clean the rest of the draining holes under the ribs along the keel of foam
4. super clean rivet areas
5. check and replace the bildge pump. i keep forgetting this cause its a pain to get in there
6. gluvit the inside
7. re attach stringers
8. add a few braces since I won't be pumping foam in
9. maybe add an additional 2 stringers (we'll see)
10. cut and install foam
If i can get this done this weekend I will be able to get the floor cut and treated and start installing in. can't wait until the floor is in. walking on those ribs sucks!!!!!!!!!!
