Hello All
Need help removing the lower unit on my Johnson 70 hp. Model is 70EL78C. I took the 4 bolts at the bottom and the big bolt at the back and the unit still want drop. I forgot to say, I did disconnect the shift shaft rod under the carbs. Did I miss anything because the unit want drop.
