shelbydriver
- Dec 13, 2002
- 173
I am running Hot on the merc 200 94 carbbed engine. runs cool at idle but then when running hard it heats up. Already replaced the thermostats, poppet valve, & hoses, and impeller with new pump cap. There is a grove worn on the driveshaft where the rubber large O ring slides down over the waterpump cap. I think it is because there is side to side play in the driveshaft under the waterpump somwhere.. It wore out the hole in the last water pump cap upon inspection.Is there any kind of sleve made for this problem. I hate to buy a new driveshaft. Is there a bearing in there I need to address? Also noted a little play on the prop bearing too. Also had a tiny bit of milkyness in the fluid. gulp. Is that groove going to make it run warm? Thanks in advance. <br />_______
