I bought a used 15 hp 1985 from someone who I thought was trustworthy.
He said engine iwas serviced and ready to run, I did start and test in tank in neutral only. I checked lower unit oil to be on safe side and realized it was not at top of vent plug. I removed drain plug and discovered that the hole was basically welded closed or filled with an epoxy. My guess is that previous owner stripped threads and did this as a cheap fix. 2 Questions
Can I fill unit with oil through vent plug?
Did running it for 5 minutes in tank in neutral cause damage to water pump or lower unit since it had no oil.?
I took it to a local mechanic and he said my only option would be to replace lower unit since filling from vent hole would not allow air to escape.
Appreciate any advice
Thanks
Thanks
