Hi Guys,
I've recently installed a 135HP Evinrude '74 outboard onto my boat to get rid of the horrible Chrysler it had.
This motor runs well, has full compression but was a little warm and had milky gear case oil.
I took it apart to replace all of the lower unit seals and water pump, I was able to change all the seals except for the bearing carrier seal.
With the 4 bolts removed using a puller and 5/16th threaded rod i was unable to extract the bearing carrier, I tried everything however its jammed good, I'd say its been run in salt water and by the age of the seals i doubt the carriers been out in a long time.
Now here's the bad part. i noticed that the carriers actually damaged where the O-ring is and the oring has been pinched and i can actually see it through the broken bearing carrier, I'd say it was damaged on reassembly years ago.
I've tried using an improvised claws but they pulled straight like some people suggested, I used a chain around the arms where the 5/16 thread is connected to a 2 arm puller, I was able to get a LOT of tension using this method and it didn't even budge, given the way the seals jammed I honestly don't think its ever going to come out. I've done this job a few times and while its a prick I've never had this much trouble. I tried heating the gear case using a butane hand torch (not excessively heated) I've run it through 6 heat cycles while applying constant pressure on the bearing carrier with no luck.
I pressure tested the lower unit with 15PSI into the crank case and could see the exposed bearing carrier outer o-ring seal bubbling where it protrudes (but no others) so i think its safe to say that the seal is cooked.
I understand my probably only option to fix it properly is to replace the lower unit and cut up the gear casing to salvage the gears as they are in assumed good condition.
any other suggestions as i'm out of ideas?
