Maybe a stupid question. On a 4.3 carburated motor, is there something that shuts off the motor if there is low water flow? Running in my driveway using earmuffs and a garden hose, it runs fine for a couple of minutes, and then shuts off. New distributor cap, rotor, plugs, electric fuel pump, cleaned and rebuilt carb, emptied fuel tank of all old gasoline, cleaned fuel pick up tube (it was clean, as well as the screen at the bottom of it), cleaned antisiphon valve, and every time I have tested the oil pressure/fuel shut off switch, it tests fine. So. I'm wondering if there is something that is shutting off the motor, there are no alarms going off, nor do I know if there would be.
Thanks.
Thanks.
