After spending time second guessing my ability to install a wiring harness on my trailer, redoing connections and grounds, I checked my Van. I am only getting 4-5 volts for the running lights- not a problem during the day but a big problem for night towing. The yellow marker lights midway back on the trailer come on but are dim, but the trailers main lights do not come on. I read about and checked the extra fuses my van has for trailer lights and they are good. All of my lights on the van work, the trailer has brake lights and turn signals but no running lights. Volt meter shows 4-5 at the van and the same at the lights? I hooked up my truck and running lights work fine. Am I missing a fuse somewhere or is the factory trailer harness bad somewhere. At $45 an hour (2 hour minimum charge) to trace the problem I would rather do this myself. I know I can just use the truck but the Van is my main long distance tow vehicle which is just about any lake I fish, plus it gets better gas milage and does not overheat while towing. Thanks.
E
E
