Are you still wanting to ride it with low compression? I wouldn't, the damage is done, and you only make the front cylinder work harder. How much difference is there between cylinders now?
running the ski is a bad idea. you currently may be able to get away with a simple fix, if you run it, you will likely make it worse. pull the head and take a look.
