sebas54
- Jun 17, 2007
- 334
HI I have a GM 4.3l merc alpha 1. I have recently removed the outdrive, and now when shifting into forward from reverse or vise verse, I hear a loud clunk. It sounds like someone is hitting a hammer against a hollow pipe. What did I do wrong? How do I fix it?
This happened to me once before when I replaced the bellows and gimbal. If I remember right I just adjusted the the shift cable and the problem disappeared. Could this be the reason?
Also I have had problem with the motor shutting off only when going into reverse. I didn't think it was the shift cable because I removed it and it was fine. I removed the shift interrupter switch and it broke off into pieces in my hand. It was a old school one that is no longer made. So I put it back together and now the stalling problem is gone but I have a loud clunk coming from the outdrive.
Please help.
Thank you.
Please help.
Thank you.
