steviecops
- Oct 3, 2003
- 585
Hi<br />I think I almost known the answer to this one, but I want make sure. Also, I suppose I'm hoping for some reassurance! Motor is a Johnson 55, two cylinder. Model number is J55EL80C.<br /><br />Last time out on my boat, I was cruising along at about 5200 rpm when the engine started to die. It slowed right down and the revs settled at around 2000 rpm. This lasted for about 20 seconds, then the revs increased back to around the 5000 rpm mark and all seemed to be normal for the rest of the day.<br /><br />Anyway, I was puzzled as to why this should have happened, so today I did a few checks. The compression came out at 150 psi on the top cylinder and 130 on the bottom. Previously they read 151 psi top, 148 psi bottom. I started and ran the engine in a water tank, and all seemed well, then I checked the compression again and there was no change.<br /><br />Do you think I have damaged the bottom cylinder? Possibly that cylinder became briefly starved of fuel for some reason when I was out last time?<br /><br />Or could it be a stuck ring? The plugs were both pretty carboned up when I took them out today. Can a ring get stuck even when the boat and engine are in pretty regular use? Or is that something that happens when the engine has sat for a period of time?<br /><br />I know I've got to try the decarb first, but won't be able to do that on the water until next week. I can do it sooner in the water tank, but obviously won't be able to run the engine at anything like WOT. Would I be better off waiting until I can get the boat on the water?<br /><br />Any advice will be appreciated.<br /><br />Thanks in advance<br />Steve
