cheaperts
- Feb 12, 2012
- 55
18' v hull glastron, 470 MC1 combo, 170 HP. Ran her out this weekend 2 people and 3/4-1/2 tank of fuel, after playing with trim had 47 mph indicated (speedo not GPS but I'm stick to it!) @ WOT & 4900 RPM. RPM is too high, I'm looking to get it into 4200-4300 range. I'm assuming I could run bigger pitch, this prop has no visible markings, is an OEM style steel prop. Is there a way to measure pitch? And will the newer style props compare apples to apples, I was told on my last boat that the newer props have more cupping on the blades and take a bigger bite than the same pitch "old style" prop. Probably a dumb question, but I admit it, I'm not a smart man (do you hear Forest Gump when you read that?)
