here she is, a 1984 glasstron conroy x17. Picked it up a couple months ago for 600$ the decks were mush, the and the motor didnt run, but it was on the original trailer, and the boat was complete, and the hull seemed to be solid. pulled the motor, tore it down and found a spun rod bearing. the block and crank have been to the machine shop, got new rods/pistons, gonna build the motor as soon as my gaskets/bearings get here. One odd thing i noticed is that the motor is a 140 hp, and the outdrive is a 120. is this something to be concerned about ? as far as i can tell, the motor was replaced, and the outdrive is original. also, is this what is refered to as an alpha 1 outdrive ? It is my understanding that there is a water pump located in the lower portion of the outdrive that should be replaced as well as changing the lube oil. anything else i need to know about the outdrive ? services to be done, or adjustments to be made ? I have pretty well finnished the demo portion of the project, now im starting the repairs, and building. the stringers seem fairly solid, however i am planning on adding to them to raise the deck about 2 inches. is there any reason i shouldnt ? i am a fisherman, and i am planning on building this boat to suit my perpose. casting decks and livewells instead of seating. also, there is no coast gaurd data plate. is that something i need to get ? all i could find is the hull sn. anny tips, and advice would be greatly appreciated. thanks guys !
