CadillacMan
- Jun 4, 2008
- 14
I have a 1989 Celebrity 265V.I just put it in the water for the first time. Water is coming into the bilge from 2 what appear to be drains coming from inside the hull that point into the bilge area at the botom of the boat. This is toward the transom at the bottom of the bilge on each side mirroring each other. There is a steady stream of water which keeps the bilge pump active. Where would this be coming from?
I cant find any info on the construction of this boat, just the tech manual of mechanics. Any info would be greatly appreciated.
Thanks,
WJShaw
I did put the drain plug in.
Thanks,
WJShaw
