Re: Lake Norman NC
As I saiD, too busy. Big rigs, water is full of boats coming from all direction, if you go on plane you need a large boat or you will have some loose teeth and some loose screws. I like to go to a lake and cruise around, find a spot, drop anchor or let the boat drift while we float next to the boat tie down to it.
However, if you get there early enough and park in the local hangout sandbar for the day it is probably not bad.
