eloham1979
- Mar 20, 2014
- 20
I was just given a farm fresh 5.5 evinrude the motor has sat in a barn for 20 years it was stuck I pulled the head an filled the stuck cylinder with tranny fluid diesel an PB blaster it took a week it is freed up good it has spark I put a large drill on it an spun th motor quite a bit after I broke it free an saw it sparking to the outer case but my main problem has been stuck bolts an I wanted to tear this thing down an put a new impeller in it an service the lower end an I was a little surprised to find when I removed the bolts from the foot there is nothing there to disconnect the linkage so I went for the motor an figured there has to be a clevice or some form of disconnect at the top my problem is I know nothing about this motor I see the flat head screws that bolt the motor to the upper pan but there does not seem to be a way to get to them it has been a chore as all the bolts have been stuck on this little motor the thing looks great an is complete but has been one heck of a bear I think the transom mount needs to come off but its being a jerk an I thought maybe I am not going about the dis assembly process right as I am sure it should not be this hard I can rebuild a automatic transmission but this thing just does not want to come apart lol thanks for any help or tear down info
