Johnson tilt and trim
marko69
Hi all been having an issue with my tilt and trim on my 1980 v4 ,the trim wouldn't go up so I checked the fluid a bit low so I topped up the leg lifted but wouldn't go down ?? so I released the screw the leg came down all fine so I thought !!!! now the fluid is leaking out of the screw grrrr ! .. Can this screw be completely removed so I can see what's up without having to remove the pump motor as I'm afloat now can't get me leg out the water
thanks for any help .......mark
You have to remove a circlip in order to remove that screw.---replace the o-rings and re-install.
