dougandmel
- Aug 21, 2007
- 25
Hi, I have a 1963 seahorase 10 hp outboard. I'm rebuilding the water pump. The parts catalog doesn't show a gasket between the impeller housing and the impeller plate, or between the impeller plate and the bearing housing (lower half of the impeller housing). Should I make a gasket for inbetween these, or use some rtv sealant around the edge? Or, does this pump not need to be sealed here?
