I recently replaced the water impellor and thermostats on my 1988 175 hp Johnson. I checked the head temp with a laser thermometer. All three heads on the left bank were running 135 degrees; the right cylinders were reading, from top to bottom, 145, 165, and 178 degrees. Can anyone tell me what the normal head temp should be for that engine and what would make the right bank run hotter than the left or is that normal due to the water flow. I would rather not pull the heads to check for blockage if not necessary.
