Should use some sealer under the plate, not necessary between plate and pump housing. Note that there is an angled hole between the pump outlet (just below the grommet) and the cup surrounding the drive shaft. That hole keeps the cup filled with water, preventing drawing air through the hole the drive shaft passes through.
