What is a good cold-starting procedure for a 1996 Johnson 88 spl? On cold starts the motor usually starts ok, but runs only a second or two before dying. I have to repeatedly squeeze the bulb and push the key in. For the rest of the day, the motor will start instantly.
My fuel system is simple consisting of 12 and 6 gallon portable tanks, standard fuel hose and bulb. Tank vent is open.
My normal procedure is to pump the bulb until hard, raise the fast idle lever all the way, push the key in for about 8 seconds then crank the engine. From there it is a flurry of squeezing the bulb, pushing the key in, and recranking as the motor sputters and dies and restarts and sputters and dies and finally starts. There must be a better way. Any ideas?
