Hi Guys
I offered to help my friend replace his water pump on his electric start 35hp Johnson Motor, j35elcnd. We had to leave the boat and motor on a rural property so i just took the leg back home with me. The main problem was that i could not work out how to release the shift level and left the water pump housing behind after disconnecting the shift level at the water intake covers. Questions are as following
1, How do i drop the shift lever to make reassembly easier
2, does the impellor slide down the drive shaft on reassembly, seems to be a one way impellor, or should it be 180dg the other way
3, the heads of the gbox bolts are rusty, the shanks look fine but should these be replaced also
4, should i replace the drive shaft seals while i have the chance, they look ok and are not leaking.
At this stage i am going to order the upper and lower water pump plate gaskets, impellor and key, water pump grommet, orings for the water pump tube, 2 drain hole washers, and am unsure on the drive shaft seals and gearbox to exhaust housing bolts. If i am missing anything please let me know, thanks.
