How do i check the timing is correct, on 92-97 johnson evinrude j6 (same as 8hp)
I have 100psi both cylinders and good spark but not even a cough with premix directly into cylinders, into intake, and same thing with starting fluid.
I have purchaced a pdf manual but it is about 550 pages and covers 1990-2001 all models. I havent been able to find the info i need but maybe i am missing it.
Is it just a flywheel key or if there is more to it, i would greatly appreciate it if someone could take the time to post the procedure.
Thank you very much
Thank you very much
