I recently aquired a 1975 johnson 40 horse outboard on a trade and it was under this guys porch lying on the ground. I imediately ran new battery cables and shorted across solenoid to check compression. Good even compression on both cylinders but during this brief test one of the coils got really hot and started smoking. I disconnected the battery quickly but the coil was damaged badly. only took a few seconds. Now the coils were very rusty and both were cracked. I removed the burnt coil and tried this again only to hear sizzling and the second coil was getting hot so I disconnected the battery again. Does anyone know if old rusty coils would do this or is there likely a different problem. The points and coils under the flywheel look like new and I can not find any short circuits in the wiring anywhere. I have checked the wires and connectors at every location.
