Re: Johnson 15hp 2-stroke high pitched noise then stopped working
i think everything is ok in this powerhead, just put new head gasket, do the head flatening in auto repair shop and bolt things back.
i think buying next motor you just run in next unknown world.
do the job with this one. you have good compresion.
unbolt side cover to look into cylinder wals and pistons wals.
if everyting is ok, just order head gasket, and gasket under side panel and bolt back everything
read LeeRoy Wisner Ramblings very careful and do the job.
you live in us and every new part to this motor is avilable, just order and do the job
to remove lover cover you should:
1. take our rewind starter,
2. unscrew lower coil, and powerpack, take them out.
now you will see 3 bolts(one under rewind starter suport, under powerpack, and lower coil)-unscreav and take them out.
unbolt lower unit, shift conector inside midsection and take out lower unit,
powerhead is bolted to mid section by 6 bolts(2 londer une just under head area, and 4 shorter one)
unscreav this bolts.
use crovbar or tire hijack to lift powerhead, sometimes just tilt side to side a powerhead.
under powerhead is a gasket, and while using motor this gasket just burn out and act as a gleue. the idea is to break tension
