foxhunterbubba
- Apr 26, 2009
- 23
i was wondering will a jack plate raise the motor enough to use my 9.9 long shaft on a 15" transom? if it will it will have to be cheaper than converting the lower unit to a short shaft.
measure from the bottom of the hull to the top of the cavitation plate, see how much movement you need.i was wondering will a jack plate raise the motor enough to use my 9.9 long shaft on a 15" transom? if it will it will have to be cheaper than converting the lower unit to a short shaft.
