contractorguy
- May 13, 2007
- 116
I've been putting together a basket case maxum 120 L-DRIVE. Pulled the head to check for damage (It was loose??). put it on, compression tested, spark tested, installed both carbs and linkages. Got the choke working, stuck the tail in a tub, the fuel line in some fresh gas, turned the key (ok...a few times) and....It started right up!... and idles pretty smooth!!! Was even pumping water!
I've got a lot of the pieces of the puzzle from you guys....Thanks.
Up next..control cables, and head to some water for some testing. BTW, I'll bring my own tow boat on the first outing!
