cwcollins06
- Jun 21, 2011
- 53
Just had my old 1976 Johnson 85 HP V4 restored by a mechanic. It was my grandfather's and I don't know much about boats/outboards so I took it to a pro but from here out I want to do things myself. He built a new fuel line using ethanol resistant lines and a new bulb and installed one of the screw on fuel/water separators in line between the tank and the primer bulb. The boat still had two original 6 gallon steel OMC fuel tanks. The fiberglass shop forgot to send one of them back (they're sending it now) but in order to go out with more than 6 gallons of fuel I bought one of the Attwood 6 gallon plastic portables and the Johnson/Evinrude fitting for the tank.
So my issue is this, with the old tank everything runs perfectly just like I remember it from when I was a kid. With the new tank it'll idle for awhile and then when I increase the throttle and start getting up to speed it sucks the primer bulb flat and dies. I can pull the fuel line off the new tank and press the pin in the middle of the stem (on the old tank there are two pins next to the stem) in and hear the "hissss" of air rushing in so I assume there's a reason the new tank isn't venting. Once I vent the tank and plug the line back in the bulb expands and I can prime it again and then run for a minute or two before the bulb sucks flat again. I've tried running with the vent in the tank cap open and with it closed, same result every time on the new tank. It looks like they used the old female fittings on the new line. Is there some kind of incompatibility between the old female fittings and the new male ones? Could the spring in the old fitting be worn out and not be stiff enough to depress the pin in the new male fitting?
Also, as a side question can I get some kind of rebuild kit for the old tanks, I'd rather use them because they fit in the tank storage area in the stern and the new plastic ones don't.
