Re: Is this boat adequately powered?
Aluminum boats typically need less power than a fiberglass boat of equivelant dimension. The question of adequate power can only be answered by what your expectations and projected usage will be. If you are just going out fishin' not in a huge hurry, and really really like the thought of getting great fuel economy, the 50 will be fine. If you have this all fire burning need to go as blazing fast as physically possible like in a bass boat, this is the wrong combo. Best bet, take it for a test run, bring your 250 pound buddy along, maybe a second buddy as well. If it seems to run adequately for what you want out if it, you're golden. A test run with foreseen load is the only way to know if the boat will be right for you. Good luck....
