Cruizer219
- Jun 23, 2017
- 8
Changed oil then got oil pressure low warning light. Hooked up pneumatic mechanical gauge and found i have about 10psi when at idle at 1k rpms, goes up to 25psi when cruising at 3k or more rpms. Will not go higher than 25psi and is a little lower when warm. Oil is SAE 30 and i changed to mercruiser oil filter but no change in pressure. Unsure if i have a problem? Runs cool, sounds fine. If i take to shop as planned, i will lose the boat for my best, last few weeks of summer! Am also curious if i should try a heavier weight of oil for this old engine.... 1982 mercruiser 140.
Thx for the irreplaceable advice,
Cruizer
Cruizer
