is there any electronics in the control box that would give me a constant sound???
MudLake
1991 johnson 40 hp
I have unplugged vro, and opened the circuit for the oil reservior.
I still get a lesser beep, its not the loud over heat beep.
Is the another signal wire i am missing?
the ignition was bad so i replaced the ignition with a new upgraded cdi solution.
cheers
ezeke
Re: is there any electronics in the control box that would give me a constant sound??
The oil tank harness and the VRO pump harness both need to be disconnected when pre-mixing.
tashasdaddy
over heat sensor. or just a bad horn.
look at ignition wiring diagrams in THE TOP SECRET FILE.
14ftgrumman
What engine are you working on?
