I am running an old SMC 43 9 x 10 prop on my 1958 18HP Evinrude 15024. The boat is a Lund C-14 Aluminum. The max HP is 20.
Last week, I decide to try a new prop I purchased on eBay (there is another thread for that topic), and marked the back of the inner hub and prop with a sharpie to see if I could detect any hub slippage. The marks are no longer aligned after about 20 minutes at WOT. I did not detect any obvious slippage, but there are some clues.
- A couple of months ago, I lot of weeds got wrapped around the lower unit. The outboard revved up high with little progress. When I removed the weeds, it seemed fine.
- The RPMs float between 4400 and 4500 on a small inductive tach at WOT. I am uncertain if this is just the flaky tach or if it is a sign that the hub is slipping slightly.
Assuming no object has been hit, is some hub slippage normal or does it always mean the prop should be replaced or re-hubbed?
