Have two battery banks with one Inverter/Charger.
Battery bank one is start battery. one 12 volt cranking battery.
Battery two is two 6v 260AH deep cycle for house.
The inverter/charger should be able to charge both banks at the same time. I have off-1-all-2 battery switch...
Switch is in All position when hooked to shore power... then to 1 for starting... 2 when on hook...etc..
Seems pretty simple, but battery one is not holding its charge from the Inverter..
Are these two batteries incompatible? what type of batteries should be used?
