My saga continues with my little 58 sportwin 10 model 10016. Got it fired up again and it was running really rough. So I put my plug tester back on and it would barley jump an 1/8, and not do that every time. Popped the flywheel off and checked the points. They were dead on, so I cleaned them, and it still barley jumps and 1/8. It has new wires, points, and cond. I screwd the new wires into the coils and have good ohm readings through the wires too the both coils. When I check the primary side of the coils, they ohm out at .1 on both. I read where they should ohm out at .9. So I am kinda at a loss. The coils look brand new, and the magnet on the flywheel will pull a screwdriver in from a inch away.
