Interior fiberglass coating
brisa
I own a 31 Cal that originally had carpet covering the interior walls in the saloon and berth. The previous owner stripped the carpet I the berth, exposing the fiberglass. I'm not a big fan of carpet and have been thinking on painting the walls with some sort of rubber-washable coat. Does anyone have a recommendation?
Thank you
Woodonglass
Re: Interior fiberglass coating
Not sure if this would interest you but...I used to build fiberglass pools and we used this paint. Really good stuff.
brisa
Thank you for answering. I will check it out.
Accepting more suggestions too:)
colbyt
Master Chief Petty Officer
Just one. Be sure to read the labels very carefully. This type of product is great but the fumes during application can be deadly.
I would also expect some lingering ordor in an enclosed space.
jbcurt00
Why rubberized?
Durabak,AwlGrip, GelCoat, Valspar Farm Implement, Rustoleum
Tractor Supply Majc: "Paint Your Boat for Under $100 Bucks"
Adding the Valspar or Majic paint hardener will give it additional gloss & improve the paint's toughness/abrasion resistance
Yacht Dr.
Thank you
I would apply a fabric of some kind with some spray adhesive and do not paint the glass.
If you ever had a repair that needed to be done it sooo much better to be able to inspect the fiberglass from the inside without having to Grind off paint.
Depends how much you want visual vs. usefulness.
A $500 repair can goto $1000 with a quick coverup of paint.
YD.
