89 VIP Valiant
- Aug 15, 2008
- 70
Hello all,
Just got the engine rebuilt on my 89 VIP with a 4.3L and an OMC Cobra outdrive. Every place I have looked most say you must use an alignment tool to line the coupler up to the outdrive. However, I did not move the bolts on the engine mounts that connect to the block, so do I ABSOLUTELY need to use the alignment tool, or can I just stab the engine to the outdrive? Also, I have done a lot of work to this 89 VIP, new floor, carpet, engine, rebuilt carb, ect. I have not done any work to the outdrive (I do plan on having the fluid changed), but have not changed the gimbal bearing, or the impeller. While I have gone this far, is there anything else I should do? If anyone has any advise on my engine alignment, or the other services I should do to the boat, I would appreciate it tremendously!
Thanks
Thanks
