No show
- Jul 16, 2007
- 63
86 celebrity 210 cutty just rebuilt the engine and I am installing the out drive. It took a little bit of finessing to get it on. Shifter was in forward all the way to get it on I lifted the gimble mounting plate and shimmed it with a wooden wire brush to lift it higher for me to make it easier to install. It went on and I had to tighten the nuts on the top to make it flush but didn't force anything. I am unsure about the installation because it said while installing it, it would make it easier if you turned the propeller a little bit, but when I did it just spins like its in neutral with a clicking sound. Is that normal? Shouldn't it lock up? Haven't started the boat but I pushed it in forward, nuetral, and reverse. I would assume at one point the propeller would lock up. I am thinking I might have to remove and reinstall. What is your input on this? Regardless of installation right or wrong can I still use the hose and the earmuffs to run and tune engine? Also when I post how can you put a picture of your boat next to your name like I've seen some others do? This boat project has been a big challenge for me and learning experience with much help from all of you fellow memebers. Thank you for all time and responses. I believe I am very close to getting it in the water.
