Initial timing 5.0gipbycce
mklearl
Trying to set initial timing. I have the procedure down, but the manual says there is a timing scale attached to the timing chain cover and timing marks on the harmonic balancer.... I see neither. The harmonic balancer has 2 dimples that look like they were made with a half inch drill... I'm thinking tdc and 8 degrees btdc... just a guess. On the timing cover, there is just a v-shaped mark, which I'm guessing is the timing mark..m I see nothing else. Can anyone else confirm the markings and tell me what I point the timing ligjt at? I'm trying to upload pics... the photos are too large. Thanks in advance!
bruceb58
You don't have this?
mklearl
Here are some pics.
Ayuh,.... Those holes are balance holes, not timin' marks,....
Look for a line across the side of the balancer,....
You'll need an adjustable timin' light, as the marks only mark Tdc,....
mklearl
Great. Thanks. This line is scribed across the balancer. I assume I match that up with the v-notch on the timing chain cover when I advance the timing light to 8 degrees btdc?
bruceb58
Apparently, you do not have the timing tab that came with a Volvo "BY" motor. If the timing cover has been changed, that mark is TDC and you will need an advance timing light to set the timing correctly. I know Bondo mentioned it...just want you to make sure you need an advance style timing light.
mklearl
Yep... got it. Set the dial on the light to advance 8 degrees. Going to give it a shot today or tomorrow. Thanks again.
mklearl
Perhaps I'm not as familiar with the process as I thought. Reading the manual it states to manually set the idle speed to 1000rpm. So I push the throttle up to 1000rpms. Then, I put a jumper wire inside the data link connector and jump the black/white to the black. This shuts off the electronic spark advance. Couple of questions with this...
What do I jump with? I looked into making a jumper wire but I can't find the pin heads. Can I just strip some wire and push it into the pin holes? Very small holes.
Second, once jumped, I would assume that I would lose rpms. If so, do I bump the throttle back up to 1000 rpms or was that just done initially to keep the motor from dying?
Lastly, when using the timing light I just want to confirm that I turn the dial on the timing light to 8 degrees advance correct? That way when my timing marks line up at tdc the light has been adjusted to 8 degrees btdc. I think the more I read into it the more I'm confusing myself! Lol. Sorry for all the amateur questions. .. I just want to make sure I get this right. Thanks again!
bruceb58
I have what right? Bump rpms up to 1000 if it dies and how do I jump the wires?
You jump the connector pins with a small wire like it says to do in the manual. Yes, you need to keep it at 1000 RPMs.
