I have a 1988 3.0. Running OK, but I noted I am getting 11.5V at the coil (stock) when idling. Per other posts I should be seeing 4-9V or so, so I am guessing my resistor wire is bad. From what I understand, what will happen in this case is I will be burning out my coil and points quicker. Is that correct? Also, are there any performance implications to having the voltage that high? Runs well, but I am only getting 4000 RPM at WOT with a 19" 4 blade propeller. I have maybe seen 4100-4200 with a 19" 3 blade prop.
