rickfmurphy
- May 29, 2006
- 4
I have a 2003 Mercury 4-stroke that has been barely used. Ther water stream is very low and I am afraid of overheating the engine. Does anyone know if 4-strokes should have similar stream flow as 2-strokes?<br /><br />I wanted to take a look at the condition of the impeller, so I bought the manual and removed the 4 housing bolts and the 1 bolt on the bottom of the cavitation plate. I expected the lower unit to slide off, but it did not budge. I did not try to pry or hit it off since I did not want to cause any damage to the cavitation plate. Does anyone have any recomendations regarding removal of the gear housing on this motor? <br /><br />I have never had to remove the lower unit on any of my other outboards and am pretty new at marine maintenance.
