Hey guys, trying to figure out my new ignition for my 1963 johnson 40 hp electramatic...
ive got battery pos. to the bat terminal
starter solenoid to the S terminal
which post does the shifter power go to?
also there are 2 black wires from the cut out switch and the magneto (i beleive) which posts do these guys go on?
my wiring diagram i got from here is great but the ignition isn't labled
i was told that They would be Starter(S), Battery(B), ground(M), magneto(M), choke(C) and ign accessory (+12VDC)(I)
so does that the ignition isn't grounded then what goes to M? and magneto M, does it matter which M you use? dont want to wire backwards...
and i take it the I post would be for the shifter powe
thanks
thanks
