need help in wiring new ignition switch on 2007 Sea Ray 210 select. has 6 prongs and old one was taken off without noting where wiring goes (not by me/lol).
you could probably make a toggle switch work, but I could see lots of serious issues doing it. Maybe if you don't want a key switch, think about an ignition toggle and a starter push button.
i bought the boat new and this is type ignition switch that came with it located on dash under ignition. there is a master key switch that must be turned on before any power works that is located near back seat under railing. i may be calling it the wrong term but that is pushed up to crank engine and pushed down to kill engine.
not your typical switch, appears to be a lighted momentary on-off- momentary on or on-off- momentary on. does it lock in a position or just there if held.
