The manual that came with my 2001 MerCruiser 3.0 states to disconect shift switch and while engine is running, place jumper between 2 white wires n dist. and set timing to 2 Deg. ATDC at 700 RPM. MerCruisers service manual #14 states to set timing at 1 deg. BTDC with all else being the same.
Question is, which one is correct? Not many engines have spark ignition ATDC and seems kind of strange to me. With the conditions above, the timing is sitting at 2 BTDC which is the service manual setting.
Can anyone tell me what this should really be?
