erosenwinkel
- Apr 22, 2011
- 130
I need to replace a faulty ignition switch on my 86 Bayliner Capri. 3 position switch with push to choke. Off, On, Turn to start and push to choke. I purchased a new Seasense switch and it is labeled on the bottom as follows.
1. Battery + (red wire)
2. Ground (black wire)
3. Solenoid (yellow wire, I assume they mean starter solenoid)
4. Choke (green wire)
5 and 6 are my problems - although feel free to correct anything up above.
My 125 Force 1258x5a has two other wires going to the current ignition switch. One is labeled on the engine as Magneto and is white and the other is also labeled as Magneto but is blue.
My new switch has two other unaccounted for terminals. One is labeled Magneto circuit and the other is labeled ignition circuit. What do I do? I have not disconnected anything yet. All existing wires look to be in perfect (long enough to work with and not all dried out and crispy) condition. I will be disconnecting the battery before attempting the switch changeover.
Thanks in advance!
Thanks in advance!
