Re: ignition conversion 15hp
Hi 20/20,<br /> I don't think the Magnatunes will work right on the '74-'76 ignition systems, as they are "maker" points, not "breaker" points. It's a low tension magneto system. Works alright when set-up right, but not always easy to do so. <br /> I think I would look for a CDI system off a 1977 or newer Johnrude 9.9/15hp. You'd need the armature plate, coils, CDI box (powerpack), flywheel and throttle cam. You'll have to either fabricate a braket to mount the CDI box, or if you have the option, steal the exhaust port cover and cylinder head off a 1977 or newer parts motor that has the mount built right in. The plug angles are different and the '74-'76 head won't clear the CDI box. This is the most involved way to convert it, but it's also the neatest when completed. An added bonus is that the '77 or newer exhaust port cover will give you an outlet to add a telltale...<br /> I've converted several of these and they run great with a lot fewer issues than the low tension mags...<br /><br />- Scott
