Iemand ervaring met Teak Foam Decking mat
NovelHadji
Hoi, mijn binnenvloer kan wel een opknapbeurt gebruiken. Ik sta op het punt om HPL aan te schaffen, maar ondertussen wordt ik ook getriggerd door het onderstaande.
het is o.a. te koop bij jachtvloeren-enzo
Heeft iemand ervaring met dit spul. Het is dus bij mij voor binnen bedoeld.
groet, Mack
English translation:
Hi, my interior floor could use a makeover. I am about to purchase HPL, but in the meantime I am also triggered by the following. It can be purchased at, among others, hunting floors-etc Does anyone have experience with this stuff? So for me it is intended for indoors.
greetings, Mack
welcome aboard. or
Velkommen ombord
looks like generic EVA foam (or fake teak). I am using something similar in my boat cabin.
briangcc
I have SeaDek on my swim pad since 2018. I've used an electric power washer (Harbor Freight special) on it with no ill effects so it's holding up very well for me. Haven't really noticed any staining...should there be, the manufacturer sells a cleaner specifically for SeaDek.
JASinIL2006
Are you considering foam (e.g., EVA) or HPL (high pressure laminate)? If you're referring to HPL, I'd make darn sure it's rated for exterior/marine use.
