I/O to outboard conversion
JosephPC
Hello,
I'm starting this thread because I have scoured the internet before I decided to do my conversion and very few threads ever showed the completed project.
The reason I'm doing this project is because the pilot house is perfect for fishing here in the northwest in the cold winter months but the I/O was always a PITA to winterize in preparation for the next fishing trip. (boat lives on Trailer)
My boat is a 2004 Trophy 2359 WA.
I had a 260hp 5.0 mpi w/ Bravo 3 in it and 22p props. I am converting to a Honda 250hp with a 30" shaft and a SS prop. (not sure on pitch yet as they have never had a boat like mine in for the conversion).
The bracket was built and installed by Dwayne of PDR marine in Bellingham WA. He has built and installed several of these brackets and if you look at most outboard Sea Sport boats his bracket will be on the back.
[FONT=arial, sans-serif]As for the transom: he was quite surprised on how well they built the boat. He didn't need any extra gussets or bracing for installing the bracket and did a magnificent job of glassing in the I/O hole along with all the other holes for the kicker and swim step. I also asked him to add a couple transducer brackets so I don't have to drill into the actual transom when installing the transducer. He said of cheesy plastic he'd make them better. (I think they look factory glassed in and gel coated) The bracket I chose was a full swim platform with kicker bracket and is standard for the positive flotation in the center. [/FONT]
It's currently in Oak Harbor WA getting the motor and all new digital instrumentation installed and should be completely finished in 2-4 weeks depending on parts availability. The dealer I had picked for the motor is very excited to do this as they have not had any Trophy boats getting the conversion. (I have not mentioned their name because I have not asked them if it's ok yet.)
I'm hoping I took enough data on the old motor to show any differences in the 2 but will be unable to GPH because I didn't have that on the boat and never tried figuring it out long hand.
The I/O would comfortably cruise at 30knt at 4k revs all day long. So if I get the 10% increase in cruising speed I should be able to get 33knts at 4k revs and still use less GPH. (we shall see)
As for the handling the boat with the Bravo 3 handled well and I'm hoping since the fuel tank and most of the cockpit being at or in front of center line of the boat I'm thinking it should make the Honda operate smoothly and hanging the motor farther back might actually help balance the COG better.
I really love my trophy and I wish they would have made the pilot house in an outboard to begin with but they didn't. So to find a boat even close in fiberglass and an outboard runs way more then what I paid for the boat and the new conversion / Outboard
I'll make sure to post up more pics as the boat is finished and has been run a bit to get more data on it even if it doesn't work out the way I hope. Please ask any questions I haven't answered in my long winded post and I'll really try and get pics and data up as fast as I get it.
Thanks, Joe
cool looking conversion
the boat with the pod on back may take slightly more hp to keep pushing thru the water than the unmodified hull simply by the larger wetted surface. your fuel consumption is based on the amount of power it takes to push the boat almost regardless of the motor pushing. 0.4 pounds of fuel per hp per hour is the standard fuel consumption of a spark ignited marine motor. dont expect a lower fuel consumption
ezmobee
That's a really neat boat. Well worth the effort to repower how you want it and the work so far is beautiful.
ondarvr
A friend of mine did the same modifications on a 23' Wellcraft WA, same motor too, use it for tuna and it works well, he eventually repowered to a Yamaha 250, both motors worked great.
JosephPC
The mercruiser was 260hp at the crank and I could be wrong but was told it's about a 15-20% power reduction to spin a bravo 3. If that's accurate then I was only 210-220 at the prop and the Honda is 250 at the prop. I really hope they were right in telling me though cause I'd hate to have a dog of a boat after doing this.
alldodge
My thought is the B3 has better efficiency then a single prop. There should be a weight reduction with the OB, so hope all is good. With Honda I'm finding the 250 is the largest they make
bashr52
Here is something similar with dual outboards:
the mercruiser was rated 260 at the prop (about 290 at the crank). all boats after the mid 80's are prop rated. with only a mild cam change you can easy get 300 hp at the prop with the 5.7
JosephPC
That's what I thought but all the Marina's I received quotes from told me that the outboards are test that way and I'd be fine with a 225 to stay at the same power but 250 would be better.
It doesn't make sense to test outboards at the prop and I/O at the crank.
prior to 1981, they were both rated at the crank. the test requirement changed and the 1981 - 1985 period was a transition period. similar to the automotive rating changes
dingbat
You will be quite surprised how the boat will react to removing #400 from transom and the change in geometry from the bracket. Done right, should push 40 mph pretty hard
JosephPC
No Title
Update on the conversion. Motor is on waiting for parts but getting closer.
JosephPC
No Title
Just a quick update. Some of the parts have been back ordered so I'm still waiting to get it on the water but that's ok. Cause it is looking awesome!! Everyone at E.Q. Harbor Marine in Oak Harbor is bending over backwards to get me the boat back and are doing such fantastic work. I've even been looking for other things for them to put on the boat because of the attention to detail is beyond premium. It'll be at least 2 more weeks before I can drive across the state to dip it but I'll get some video and pics when i do and post them up along with some #'s. Thanks for reading, Joe
hvymtl939
This is so awesome! The admiral and I's dream project some day is to find a Sea Ray or similar decently big cabin cruiser (28-33'), do a restoration, and convert it to OB, like the new Formula cruisers are. Can't wait to see the final results!
JosephPC
No Title
Hello everybody,
Well I got the chance to test run the boat today before dragging it home. All I can really say is......... Awesome! I don't mean awesome as a loose term either. This thing is truly awe inspiring. I'm still in the break in phase and the thing will do 40 MPH without batting an eyelash. I even had one of the fish box pumps fail so I'm hauling a bunch of water around ( 32 GAL) that isn't needed and it still does great. The idle to plane is fantastic. The boat doesn't cruise at the same speed it used too but it hops on plane at half the time and feels like it's way more maneuverable then before. Cruising speed is currently down about 4 MPH at 4000 revs but this motor tops out at 6k vs the I/O at 5500 so I'm not sure if it's actually falling behind at all. I am impressed and believe it is worth every penny I dished out to get this. I will have some video links added as well to show some more performance shortly as well. The video I took today decided to cut and start a new one about 1/3 of the way into it but i'll try and post it anyway and get some more for everyone. Thanks for reading, Joe
